I'm using a ADSP-SC573. I setup an SPORT.
Why does the SPORT send unnecessary clocks before sending the actual first byte. This is a waste of time (see figure below, red marking).
I setup my SPORT like this:
/* open the SPORT driver */ ADI_SPORT_RESULT eResult = adi_sport_Open(0, ADI_HALF_SPORT_B, ADI_SPORT_DIR_TX, ADI_SPORT_SERIAL_MODE, DeviceMemory, ADI_SPORT_DMA_MEMORY_SIZE, &hDeviceTx); /* * Use the driver API's to configure SPORT * * adi_sport_ConfigData(); * adi_sport_ConfigClock(); * adi_sport_ConfigFrameSync(); */ /* configure the sport for data length, LSB first etc */ eResult = adi_sport_ConfigData(hDeviceTx, // hDevice ADI_SPORT_DTYPE_ZERO_FILL, // eDataType 7, // nWordLength (7 = 8 bits) false, // bLSBFirst (false : MSB first (Big endian) ) false, // bEnablePack (false : Disable DMA packing) false); // bRightJustifiedMode (only for I2S mode) /*configure the clock for the SPORT. This API set the whether use the internal clock, SPORT clock etc */ eResult = adi_sport_ConfigClock(hDeviceTx, // hDevice 100, // nClockRatio true, // bUseIntlClock (true : Device configured to use Internal clock) true, // bFallingEdge (true : Use falling edge of the clock) false); // bGatedClk (false : Disable gated clock mode) /* Configure the frame sync. This API configure the SPORT whether to use frame sync or not , external or internal framesync etc */ eResult = adi_sport_ConfigFrameSync(hDeviceTx, // hDevice 8, // nFsDivisor (8 clk slots where FS is not active) true, // bFSRequired (true : Device requires a frame sync for its operation) true, // bInternalFS (true : Use internal frame sync) false, // bDataFS (false : Use data-dependent frame sync) false, // bActiveHighFS (true : Use active high frame sync) false, // bLateFS (false : Use Early frame sync) false); // bEdgeSensitiveFS /* Enable the DMA mode */ eResult = adi_sport_EnableDMAMode(hDeviceTx, true); /* Register a callback for the DMA */ eResult = adi_sport_RegisterCallback(hDeviceTx, SportCallback, NULL);
The data I'm sending is:
uint8_t data[] = {0x81, 0x00, 0xF0, 0xF0, 0xBA, 0xAD, 0xC0, 0xFE, 0xEA, 0x31, 0xC0, 0x00, 0x12, 0x34, 0x56, 0x78};
Am I doing something in my setup to cause this behaviour?
Had to change a comment in the inserted code.
[edited by: masip at 7:41 AM (GMT -4) on 24 May 2021]
