Hey there,
Im developing software to do a block convolution. Im receiving data from the SPORT based on your ADC DAC Audio Playback example code.
Now im trying to read data in between from de SDRAM via DMA. This action gives distortion to the output cause i think it interrupts the SPORT DMA proces.
Im not quite getting how to organize the DMA, is it possible to run these DMA concurrent? Cause eventually i also want to implement the FFTA accelerator and this is also driven by the DMA right?
Gr
Hi,Apologies for the delay caused.We have simulated your issue in ADSP-SC589 EZkit.To narrow the down the issue, we have done below tests.
1.Having suspect in cache for SDRAM access we also do flush call…
Moved to CrossCore Embedded Studio and Add-ins Community.
Hi,Could you please answer our questions below. This will help us to assist you better.1. You have mentioned that you are trying to read data in between from SDRAM via DMA. Please confirm whether you are using MDMA or please explain the process.2. Please confirm which DMAs you are trying to use concurrently.3. Please explain the process of your application in detail.4. If possible, please share us your modified Audio Playback example in order to simulate your issue here.Regards,Nishanthi.V
adc_dac_playback_Core1.rar
Hello thanks for your reply. I attached the code.
To communicate with the SDRAM i am using the MDMA pipelines. I tried MDMA 0 to 3 to check if there is a difference. but all of them give a distorted signal.
And the SPORT uses DMA10 and DMA11. When the buffer is filles i read data read from the IR from SDRAM with MDMA and execute a convolution with the 64 blocks. and if im correctly the SPORT ping pong buffer is being filled on the background?
i hope this will suffice for you to help me.
Gr Brian
Hi Boehlers,Apologies for the delay caused.While testing your code, code hangs at line no:245 WAIT_FOR_DMADONE(9);that means we have faced address alignment error in MDMA0 channel 8 and MDMA2 channel 39 status register.i.e DMA_STAT.ERRC=2MSIZE is configured as 32 bytes which is not matching with xmod paramater (4) as belowMDMA_CONFIG(8, uiSourceDMACFG, pSrc, 4, buffer_size*2, 9, uiDestDMACFG, pDst, 4, buffer_size*2);And also DMA_ADDRSTART register(Src/Dst) is not aligned according to the DMA_CFG.MSIZE field.Can you please confirm that whether you face this issue or not?If you face this issue, please find below suggestions.1.Do the alignment for buffer address.#pragma align 32complex_float dm cfAudioProcFreq[AUDIOINBUF];2.Change Xmod to 32.MDMA_CONFIG(8, uiSourceDMACFG, pSrc, 32, buffer_size*2, 9, uiDestDMACFG, pDst, 32, buffer_size*2);MDMA_CONFIG(39, uiSourceDMACFG, pSrc, 32, buffer_size*2, 40, uiDestDMACFG, pDst, 32, buffer_size*2); Regards,Nishanthi.V
Yeah my apologies, i tried a different config for the DMA MSIZE and forgot to put it back to 4.
This was not the original issue I had. The issue is that when i played the audio the DMA function distorted the output audio. Because i think it interrupts Ping Pong buffer bucause this is also transfered through DMA .
