ADSP-BF706 EZ-KIT Mini: run without debug in CCES [solved]
Hi there,
How can I run the audiofilter callback example code without being in debug mode.
I want to make a vocoder so it's important for me that the device is not hooked on a laptop while it's debugging.
I found some info about the Command Line Device programmer but I dont understand how it works and the reason for using it:
"you can only make use of this utility via a Command Prompt window", but thats super vague.
why would I need an extra command prompt to program my microcontroller.
Isnt CCES suppose to do that for me.
Until now, I was STM32 and Eclipse for my project so maby im just in a technical cultrure shock.
I hope someone can tell how I can program with CCES or maby explain how to work with CLDP
- Jan Pieter de Rie
Same question but did not understand the answer
https://ez.analog.com/dsp/software-and-development-tools/cces/f/q-a/67707/running-bf706-without-connection-pc
solved
[edited by: JPdeRie at 8:44 PM (GMT 0) on 26 Jan 2020]
