error in pint gpio driver
Hi guys.
I am working with bf609 using crosscore 2.8.3. In the process, I found an error in the gpio driver (adi_gpio_pint.c revision 32169)
instead of the usual assignment to the set and clear registers, reading the register, adding bits, and only after that assignment is used. as a result, when you try to reset one bit (for example, a mask), the entire register is reset.
Is there any need to report this problem somewhere? or maybe I have an old driver?
