Timer interrupt delayed with LwIP stack
Our firmware should trigger an interrupt every 50kHz and generate a low/high pulse at PF5.
The source code for the timer interrupt looks like this:
void Init(void)
    result = adi_int_InstallHandler(ADI_SID_TIMER0, _TIMER0_INTERRUPT, 0, true);
    *pSIC_IMASK |= IRQ_TIMER0;
    *pTIMER_DISABLE = TIMDIS0;
    *pTIMER0_PERIOD = 2400
    *pTIMER0_WIDTH  = 0;
    *pTIMER0_CONFIG = PWM_OUT | PERIOD_CNT | IRQ_ENA;
    *pTIMER_ENABLE = TIMEN0;
static void _TIMER0_INTERRUPT(uint32_t iid, void *pCBParam)
    *pPORTFIO_CLEAR = PF5
    *pTIMER_STATUS = TIMIL0;
    *pPORTFIO_SET = PF5
The problem I have is that the timer interrupts with a delay, but only when the LwIP stack is used.
If the stack is not used, the interrupt always strikes correctly.
To illustrate this, I have attached 2 images of the LogicPort Analyzer:
ConvSt (Timer0) without LwIP Stack:
ConvSt (Timer0) with LwIP Stack:
I am using CrossCore Embedded Studio v.2.8.3 with the Lightweight TCP/IP (lwIP) Stack v.2.6.0.
I used the BF537 processor with CoreClock 600Mhz and SysClock 120Mhz on a own hardware board.
I have tried several LwIP configurations and changed the thread priorities of the LwIP stack. Unfortunately all without success.
Can you help me with this problem?
Thanks.
SONSDM
tagged
[edited by: JValeriani at 3:07 PM (GMT 0) on 14 Oct 2019]
