ADAU1446 CLKOUT modulating
Hi. I've built a prototype using the ADAU1446 using the CLKOUT as fs*256 to clock a CODEC. It's working and I'm not conscious of any problems with the output signals that might be caused by the master clock. However, CLKOUT appears to be frequency modulating at about 24kHz (fs=48kHz), the oscillator itself is stable. As best as I can tell fs is also stable. Any ideas? Is this something I'm likely to see using the fs*256 option? Would I be better using the buffered oscillator? tia Gordon
  • Error. It's modulating at 48kHz. I was looking for when it came back in sync but missed the first 'node'.
    Gordon
  • Hello Gordon,
    We haven't seen this kind of behavior on the evalution board of the ADAU1446. In order to provide you with further assistance, we'll need some more detailed information about your application and setup.
    1 - Please provide your SigmaStudio project file. If you're concerned about showing your signal flow to the public, then you can simply delete all of the cells from the schematic tab. The only information I'm really concerned about is the register settings.
    2 - Please provide a schematic or basic description of the hardware, specifically the interconnection of the ADAU1446 and the codec.
    3 - Please provide any scope shots that might help us to better understand the issue.
    Best Regards,
    Brett
  • Hi Brett. Thanks for the response. You've given me some pointers so I'll cut a few tracks and pull a few R's before troubling you further. I'll post back if I can narrow the problem down a bit.
    I'll try and get some scope shots anyway but it might not be very informative. I check it by setting the A time base to 0.5us then increasing the delay on the delayed trace set at 0.05us. As you increase the delay you see what looks like jitter but as it approaches ~4.2 the 'jitter' disappears. Increase the delay further and the 'jitter' comes back to disappear again at ~8.4. So what you see depends on the delay position.
    Doesn't do it until it's been compiled if it helps. I've had the circuit right down to a minimal setup so don't /think/  it's down to the circuit itself. I'll have another basic circuit test tomorrow.
    Cheers
    Gordon
  • Hi Brett. Disconnected everything from the CODEC, no change. If I reduce the schematic to it's bare minimum, the 'jitter' reduces. I can't get a decent scope shot, sorry. Project file attached. There isn't really much to the circuit once the codec's disconnected. It's running at the default 48k with component values for PLL as per ADAU1446 spec sheet. CLKOUT as I've said is running at 256*fs, CLKMODE0=LOW, CLKMODE1=HI. RSVD and RST tied low. SPDIFO is driving one of these http://tinyurl.com/y8uj6rz. SDATA_IN0 is the only input. MP10 has a 10k pullup. All other MP pins are open as they go out to a header which isn't plugged in. CLATCH is tied to ground. It's a two layer board and all chip power pins are decoupled as close as I could manage to the chip. No uP, just an EEPROM which is working/self booting OK. The crystal is the same one used on the ADAU1701 evaluation board. Remember, it only 'jitters' once it's been compiled.
    Won't expect to hear from you before Monday.
    Have a good weekend.
    Gordon
    1446-Modulation.dspproj.zip
    The Reset pin is active low, so if this is true, you are essentially holding the chip in reset/standby mode. Is this correct, or a typo?
  • It is tied low with a 10k but driven by the reset pin of an ADM811T. Forgot about that, sorry.
    Gordon
  • Hi Gordon,
    Sorry for my late reply. I was holding off on my reply until I could duplicate your issue in the lab, but unfortunately I wasn't successful in doing that. With a variety of settings, my MCLKOUT signal is locked rock-solid to the other clocks on the board. I don't see frequency modulation or jitter of any kind.
    Of course, all real-world systems have some jitter, but on my hardware, I'm unable to see anything on the order of magnitude you're seeing.
    Any more information or steps for reproducing the issue would be helpful. Unfortunately I'm at an impasse now since I can't see the problem in our lab.
    Brett
  • OK, thanks for trying anyway. If I find out what the problem is I'll post back here.
    Cheers
    Gordon
  • Well, the good news is that the circuit is now working as it should AFAICS. Switched the CLKOUT mode to the buffered oscillator and CLKOUT is stable. Couldn't find out why  CLKOUT=fs*256 modulates. It appears the modulation *was* interfering with performance. At 24kHz input the output would modulate at some quite low frequency which is why the low pass filter was on the input of the previously attached project file. It still does (without the low pass) but at a *very* low level.
    All's well that ends well.
    Cheers
    Gordon
  • Hi Gordon,
    Thanks for the update. I'm still unable to duplicate this problem but I will keep an eye on it and inform the designers. If I have any updates, I will post again in this thread. Please feel free to do the same if you have any new information regarding this issue.
