Adding TOSLINK / optical input to 1701 project?
I have an older design using an ADAU1701, and we'd like to upgrade it to include consumer-grade TOSLINK (optical input), but I don't want to add too much cost.  From my reading, this gets complicated, because the master clock for the ADAU won't be synchronized with the external source.  So I assume I'll need an ASRC.
I see a few options -
1.  Add a chip to convert S/PDIF to I2S as a slave to the source, then use an ASRC to sync the digital data into the ADAU1701.  This seems quite complicated, but maybe there's a cheap IC somewhere that does all this?
2.  Convert the S/PDIF into analog, which is mux'd or mixed to the ADAU analog input.  This probably requires a receiver + DAC, so $$.
3.  Switch to an ADAU1442 or similar (adds $5), which handles the digital side nicely, but requires a codec to retain my analog capability, so that's another $2 or so.  The extra processing is nice but I don't really need it.
Given that this type of input is so common in inexpensive consumer gear, I'm surprised it's turning out to be so expensive - easily $5 plus the connector in quantity.
Any other options I'm overlooking?
  • Nice work, thanks for sharing.
    This might be the most expensive way to do it, though!  The AD1895 is $6, and the WM8804 is $7, so that's a lot of added cost.
    Curious - why didn't you have the ADAU1701 be a clock slave from the WM8804, so you wouldn't need the AD1895?
  • ADAU1445 is about $12, plus a $2 DAC (codec, really), so that's about a $10 increase in price.  A lot for a consumer item.  I was hoping to find a solution in the $2 range.
  • I have begged ADI to consider S/PDIF in future (smaller then -1445) SigmaDSP chips.  My dream chip would be -1772 with S/PDIF and a -1701 core.  More voices in support would be merrier!
    One possible reason to use AD1895 between the Rx and -1701 is so that -1701 doesn't have to reset & load a new program for incoming sample rate changes (for example if its analog inputs have to keep running while the digital inputs are muted while acquiring a new lock).  It also lets you pretend to run at double-speed rates while retaining the single-speed instruction set in the -1701 core.
  • Well hopefully ADI is listening to my begging as well.
    I can see that benefit from the AD1895. I can live without continuous analog inputs briefly during a switch to digital.  (I don't expect many sample rate changes from consumer connections though.)  A reload is a bit of a hassle, but it's workable.
    I think I'll have to try the DIR9001.
    You have my voice in support too!!
    AD should also release register control interface to the hardware configuration tab in SigmaStudio for ADAV4601.
