Dear Sir,
I can't find ADAU1962 & ADAU1978 in SigmaStudio (Ver 3.13).
Can you please kindly advise how to find these two component or is any library that I can import to SigmaStudio?
Thanks very much !
Henry
Dear Sir,
Thanks very much !
Henry
Hi Tang,
Both of these parts have their own control GUI. You need to download from the product page.
For ADAU1962A
http://www.analog.com/en/products/audio-video/audio-codecs/adau1962a.html#product-…
Hello Tang,
For the ADAU1962A, you can use SigmaStudio to control it. You also can use the ARWB program if you like. The SigmaStudio DLL is labeled ADAU1966. This DLL will work for the 1962, 1966A and…
Hi Tang,
As mentioned in my earlier reply, the ADAU1978 is not supported in sigmastudio library. However there is standalone GUI for the ADAU1977/78/79 parts. The GUI uses the same USBi board. Download…
Hi Tang,
For ADAU1962A
http://www.analog.com/en/products/audio-video/audio-codecs/adau1962a.html#product-documentation
For ADAU1978
Thanks
Rajeev
Hello Tang,
For the ADAU1962A, you can use SigmaStudio to control it. You also can use the ARWB program if you like. The SigmaStudio DLL is labeled ADAU1966. This DLL will work for the 1962, 1966A and 1962A. The small differences will not effect the operation of the part. Of course any controls for channels above 12 will not work because it is only a 12 channel DAC. Also, the settings for the common mode voltage cannot be set to 5V for the "A" version of parts that operate only at 3.3V. So the differences are rather obvious and you cannot damage the part by selecting them.
Dave T
Hi Tang,
As mentioned in my earlier reply, the ADAU1978 is not supported in sigmastudio library. However there is standalone GUI for the ADAU1977/78/79 parts. The GUI uses the same USBi board. Download the GUI from the link below under Software tab
Regards
Rajeev
Hi Rajeev,
Understood and thanks very much for your explanation!!
Thanks very much!
Henry Tang
