We are using the ADAU1467 with the additional SDATA input lines for our ADCs but we cannot get a working configuration for the IOs.
Is this feature even yet implemented?
Sigma Studio 3.16B1R1744 in use
There has been some confusion about my answers above, so I will try to summarize:
To add additional clarification, please note that if the following are true:
If all of these are true, then either the BCLK or the LRCLK must be generated from another pin.
gotoh: You are seeing a user interface bug in version 3.16 of SigmaStudio. The mode you need works with no problems on the silicon. The GUI should not show that this is an invalid mode. If you have any problems making this work, please let me know.
Ken
Ken
The serial input port must be configured as a TDM4 input, and data will appear on even numbered channels (0/2/4/6/8/10, etc). No data will be lost as a result of this change.
Additionally, if the external clock master is functioning exactly as the DSP is configured, you may change the "LRCLK Type" to Pulse (even though it's actually being received as 50/50) and data will appear on the standard channels (0/1/4/5/8/9, etc) and can be passed through ASRCs in stereo pairs.
Please see this post for more detail:
https://ez.analog.com/audio/f/q-a/122099/sdataio-is-not-working-correctly-of-adau1463/363509#363509
Joshua
