Here the problem. I read in the ADAU1701 datasheet, that I have to set "Set multiple writeback" so that every time I change parameters, a writeback occurs... By default writeback is only enabled "one time" (normally used during power down). Could someone show me the position and the value of the byte I have to modify? In Sigmastudio Hardware configuration IC2, in the Display File, could someone tag the hex number I have to change to set multiple writeback? There's something other parameter to "enable" writeback in the EEPROM?
Thanks a lot,
Charlie.
