Dear Team,
We are evaluating the ADAU1797A for a hearable/audio application and need to implement a custom feature extraction algorithm (statistical/spectral analysis of the incoming audio stream) directly on-device, beyond what the standard SigmaStudio+ block library offers.
Before investing further, we'd like to understand the current, real-world maturity of the C/C++ development path on the HiFi 3z core. We found the following public forum history and want to make sure we have an up-to-date picture:
In May 2024, an ADI engineer noted in this thread (ADAU1797 Compatibility, https://ez.analog.com/audio/speech-processing-solutions/f/q-a/582821/adau1797-compatibility/528089) that the "SS+ ADU1797Z platform is not yet publicly available," and a customer in the same thread reported being unable to locate the HiFi platform option in SigmaStudio+, encountering crashes on update, and missing SDK documentation.
In December 2025, a different ADI engineer, responding to a related question (ADAU1467 vs. ADAU1787 vs. ADAU1797A, https://ez.analog.com/dsp/sigmadsp/f/q-a/601569/adau1467-vs-adau1787-vs-adau1797a), still described the HiFi 3z path as "opens up a lot of complications" and stated this would require being connected directly with a dedicated support engineer.
We're aware of the general SigmaDSP FAQ stating that custom C/assembly coding is not supported on the classic SigmaDSP core — our question specifically concerns the HiFi 3z (Tensilica) core on the ADAU1797A, which according to the datasheet supports direct C/C++ programming via Xtensa Xplorer, distinct from the classic SigmaDSP architecture.
Could you help us understand:
1. Is the SigmaStudio+ HiFi platform and SDK for the ADAU1797A now stable enough that a customer can independently write and deploy fully custom C code on the HiFi 3z core, without requiring dedicated support intervention just to get started?
2. Is there existing example code for a custom feature-extraction-style algorithm on the ADAU1797A specifically, similar to the ADAU1860 examples ("Moving Data to Hifi3z Block Based," "Moving audio data to Hifi3z Core Sample by Sample")?
We'd like to get a clear, current picture before committing further evaluation time and hardware purchase. Happy to continue any more detailed discussion offline if needed.
Thank you in advance,
best regards
Peggy
