Hi David,
As I have posted in the wrong space (Precision Microcontrollers), Now I am posting in the sigma DSP section.
Now I am replying to the answer mentioned in the Precision Microcontroller section,
In the Line Outputs section of the ADAU1761 datasheet, the following statement is provided:
"The MX5G4[1:0], MX5G3[1:0], MX6G3[1:0], and MX6G4[1:0] bits can all provide a 6 dB gain boost to the line outputs. This gain boost allows single-ended output signals to achieve 0 dBV (1.0 V rms) and differential output signals to achieve up to 6 dBV (2.0 V rms)."
Could you please verify whether the specification indicating 2.0 Vrms differential output is correct?
Also, I plan to use the Line Out pins as headphone outputs by setting the LOMODE (R31) and ROMODE (R32) bits.
kindly review the shared schematic and confirm whether the implementation is appropriate for headphone mode operation, both for 16 Ω loads and for higher impedance headphones.
Muthu
