Hi, ADI
I'm using the adau1777 to do the noise cancelling project. Now, we are blocked by a carak noise problem from one of the speaker with a fixed dac_sdata value.
In my schematic design, two pieces of adau1777 are used, and they are synced by two bclk clocks tied together. And just one is set as clock out mode, other adau1777 and dsp processor
are set as clock in mode. Usually, they work OK, but some time there is a crack noise comes out from one speaker. We used the oscilloscope to capture the i2s signal and the
dac hpout, we found the fixed dac_sdate still produce a ripple voltage on the dac output, as below picture shows.
So, would you please help us locate the root case, thank you very much.
ch1 (yellow) is the dac out (hpout), and ch2 (blue) is the i2s dac_sdata signal.
overall view of adau1777 layout
top layer
inner 1 layer
inner 2 layour
inner 3 layer
inner 4 layer
bottom layer
