SigmaDSP Serial Out Clock Sync?
I have an ADAU1452 with a 24.576MHz crystal on the XTAL pins generating a clock. A DAC is connected to the serial out ports and to MCLK Out. The DAC specifically states that BCLK must be synchronous with MCLK.
If I set 'BCLK is Master' and LRCLK is Master' in the serial out window, is this synchronous with the MCLK? The frequencies seem correct.
Thank you!
