I've started to use the State Variable (Q/F input) block and I'm observing that changing the Q also changes the frequency, please see pictures below that show this.
Change Q to 10:
Increasing the Q reduces the frequency peak and vice versa. The problem is when trying to set the Q to something sensible like 0.7 then the frequency increases signifcantly and above nyquist, corrupting the signal, which makes setting and controlling this filter pretty awkward.
Have I made a mistake somewhere or is this a bug? If it's a bug, will it get fixed? I'm using version 4.7.
Thanks.
