ADAU1787 appears to have specified input/output latency, but other processors do not.
What is the approximate input/output latency for the other sigmadsp processors?
ADAU1787
Recommended for New Designs
The ADAU1787 is a codec with four inputs and two outputs that incorporates two digital signal processors (DSPs). The path from the analog input to the...
Datasheet
ADAU1787 on Analog.com
Hello harmerb,
You will have to give us more information.
Which processors?
Some have codecs some do not.
If latency is an important issue for your application then the ADAU1787, the ADAU1777, that ADAU1772 and the ADAU1797 are the processors you will need to be looking into and those are all designed to be low latency and so there are specs published with those details.
Dave T
