KCC Quizzes AQQ303 about the radius of a circle
1. Quote of the month: "When I die, I want to die like my grandfather who died peacefully in his sleep. Not screaming like all the passengers in his car" - Will Rogers
2. Quiz AQQ304 about finding the radius of a circle
Good luck, and try to be
August Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Important: Read the blog first . The quiz questions are all based on the content of the blog:
Stay in the loop and win! Read the blog Current Output Driving Industrial Loops , then take our quick five-question quiz for a chance to win a gift card
ADAU1701
Production
The ADAU1701 is a complete single-chip audio system with a 28-/56-bit audio DSP, ADCs, DACs, and microcontroller-like control interfaces. Signal processing...
Datasheet
ADAU1701 on Analog.com
AD8592
Production
The AD8591, AD8592, and AD8594 are single, dual, and quad rail-to-rail, input and output single-supply amplifiers featuring 250 mA output drive current...
Datasheet
AD8592 on Analog.com
Can anyone recommend a low component count Stereo headphone IC for the ADAU1701 to drive 8ohm to 16ohm headphones?? example schematics for ADC out pairing would also be helpfull
Thanks
Hello CANbed,
8 or 16 ohms for headphones is quite low. I did find this post on the Amplifiers section of the forum. (+) AD8592 for Headphone Amp - Q&A - Amplifiers - EngineerZone (analog.com)
I suggest you ask this question over in that space. We do have some good high current opamps that may fit the bill. We do also have a lot of actual headphone amplifiers from the Maxim catalog. Here is the selector guide page: Selection Table for Headphone Amplifiers | Parametric Search | Analog Devices
You may find that most of these will not drive much below 32 ohms.
You might want to look at the class AB speaker amplifiers. Selection Table for Class AB | Parametric Search | Analog Devices
These all can drive down to 8 ohms and I think all of them will put out more than 1W which is really too much for headphones but it will go loud!! You would have to employ some sort of level protection to prevent anyone from damaging their ears. So for that reason I would be very careful and it is not the intended use for the amplifiers.
Dave T
Thanks for the Reply Dave, ad yes, have been looking through some Designs in regards to protection :)
