Controlling a external device through i2c (Sigma350 family) not working
Software Version: SS 4.7
Hi everyone,
I'm trying setup a PCM1865 through my ADAU1466 using the Master Control Port I/O block.
I tryed different ways to do this, never worked.
Can someone explain me the XML file? If mine is correctly configured?
The ADC serial control port use 16-bit data words
The ADC address is 0x94 8-bit, 0x4A 7-bit (last one modified by the R/W bit)
The register address is 113 and I need to configure to 0000 1111 binary, page 0, as this picture (mute all inputs):
The first try XML:
After that, I tried:
Without "Dspname"
With 00 0F and len="4" on register 113
Without page select
With address byte length=1 in xml and block (Mistake? Don't know, i'm just trying every combination possible)
Block configuration:
Ps.: The xml file is in the same folder as the project.
Ps2.: My i2c e2prom is in the same bus (master i2c), so the bus is working.
Thanks by advance
