decimal to 5.23 conversion
Software Version: Sigma Studio version 4.5 Build 1, Rev 17916/24/2020
I am building FIR block in SigmaStudio which I intend to implement on ADAU1761.
I have FIR coefficients (from Matlab) in decimal format and I convert them to 5.23 format using to523 procedure (Microsoft Word - SigmaStudio.doc (amobbs.com)).
void To523( double _param_dec, BYTE* _param_hex)
int param223;
int param227;
//multiply decimal number by 2^23
param223 = _param_dec * (1 << 23);
//convert to positive binary
param227 = param223 + (1 << 27);
_param_hex[3] = (BYTE)param227; //get byte 3 (LSBs) of parameter value
_param_hex[2] = (BYTE)(param227>>8); //get byte 2 of parameter value
_param_hex[1] = (BYTE)(param227 >> 16); //get byte 1 of parameter value
_param_hex[0] = (BYTE)(param227 >> 24); //get byte 0 (MSB) of parameter value
_param_hex[0] = _param_hex[0]^0x08; //invert sign bit to get correct sign
The output of To523 procedure gives me values that are slightly different than I get in SigmaStudio.
For example when To523 procedure decodes decimal 0.000180319592330146051886718971957179747 it produces _param_hex 0x00 0x00 0x05 0xE8 while SigmaStudio gives 0x00 0x00 0x05 0xE8.
What is wrong with To523 procedure?
Wlodek
