Sigma studio "Link compile download".
Product Number: ADAU1457
Software Version: Sigma studio 4.6
HI.
I create a project that run in ver 4.5 in my previous computer with no problems.
When I switch to my new computer and install sigma studio  ver 4.6 , i open the project ( which run on my previous computer) and run " Link compile download.
However I didn't see that the code is working . No signal appeared in the output.
Can you advice what to do . (May be a drivers update  needed?)
  • Hello menashe,
    Could you please tell me whether your project didn't even compile that is you are getting any error while compiling or It just compiled and downloaded well but you didn't get an output signal ?
     If you are facing any errors or like crashing of program or just opened and closed , please just check the below things ,
    Could you please check the Operating system on both the computers? Are both same?
    Are you using any add-in features that required separate installation?
    If you create a new project on the PC showing an error message, add a component, save, and reopen, does that work?
    Issues are noted with SigmaStudio running in virtual machines (VMware, etc) and it's recommended to run on a default Windows machine.
    Please check whether all the respected DLL's are added and checked in Tools>>Add-ins-browser that is located on top left corner of SigmaStudio.
    If you get your project compiled and didn't get the output signal then kindly attach your project we will quickly have a look and get back to you.
    Harish
  • Hello Harish,
    I am working with Menashe, please see attached 2 projects: "test tone" and "project 1".
    we tried to run link compile download on both and we succeeded to run only on test tone with version 4.6 of sigma studio.
    can you please check?
    many thanks
    Shahar
    ADAU145X Assembler, Analog Devices Inc.
    Version: 4.6.0,1809  (built 12/23/2020)
    ##### Compile Started: Tuesday, June 14, 2022 9:49:16 AM #####
    ##### Compile succeeded:  0 errors, 0 warnings #####
    ##### Summary #####
    DM0 RAM used:       00037    (of 40960)
    DM1 RAM used:       00014    (of 40960)
    PM  RAM used(Data): 00000    (of 24576)
    PM  RAM used(Inst): 00115    (of 24576) 101 instructions (32bit: 87  64bit: 14)
    Total PM used:      00115    (of 24576)
    STREAM                        Inst      Inst      DM0     DM1     PM
    Instance                      (cycles)  (size)
    STACK                          -         -        16      0       0
    FRAMEWORK                     60        42        4       8       0
    Tone1                         18        18        10      1       0
    Single 3_5                    8         11        3       1       0
    Output3                       2         2         0       0       0
    Total                         88        73        33      10      0
    (% Fs=48.0kHz)                2%        1%        1%      1%      0%
    test_tone.dspproj
    ##### Compile Started: Tuesday, June 14, 2022 9:52:50 AM #####
    ##### Summary #####
    DM0 RAM used:       21758    (of 40960)
    DM1 RAM used:       03144    (of 40960)
    PM  RAM used(Inst): 04906    (of 24576) 3829 instructions (32bit: 2752  64bit: 1077)
    Total PM used:      04906    (of 24576)
    STREAM fs=48000               Inst      Inst      DM0     DM1     PM
    STACK                          -         -        68      0       0
    FRAMEWORK                     200       206       177     8       0
                                  149       105       99      102     0
    AVC1                          91        99        36      29      0
    Compressor1_3                 48        55        61      1       0
    Compressor1_2                 48        55        61      1       0
    Gen Filter1_7                 21        38        6       15      0
    Gen Filter1_16                21        37        6       15      0
    Gen Filter1_15                21        37        6       15      0
    Gen Filter1_24                21        37        6       14      0
    Gen Filter1_5                 21        37        6       14      0
    Gen Filter1_4                 21        37        6       14      0
    Gen Filter1_23                21        37        6       14      0
    Gen Filter1_20                21        37        6       14      0
    Gen Filter1_21                21        37        6       14      0
    Gen Filter1_26                21        37        6       14      0
    Gen Filter1_25                21        37        6       14      0
    FIR2                          60        32        192     194     0
    FIR1                          60        32        192     194     0
    NR_HIGH                       16?       19        1       1       0
    NR_LOW                        16?       19        1       1       0
    NR_HIGH_2                     16?       19        1       1       0
    NR_LOW_2                      16?       19        1       1       0
    Level2_23                     13        15        14      1       0
    Level2_21                     13        15        14      1       0
    Level2_22                     13        15        14      1       0
    Level2_19                     13        15        14      1       0
    Level2_18                     13        13        14      1       0
    Level2_20                     13        13        14      1       0
    Single 3_5                    8         13        3       0       0
    Nx1 Linear1                   6         10        2       1       0
    Input1                        8         10        0       4       0
    Single 1                      6         8         4       1       0
    Single 1_2                    6         8         4       1       0
    DownSampling2                 6         8         0       2       0
    Single 3_4                    6         7         4       0       0
    Gain2                         5         7         1       1       0
    Single 3_7                    6         6         4       0       0
    Single 3_6                    6         6         4       0       0
    Output3                       2         3         0       0       0
    (? Jump instruction present, actual cycle count may differ.)
    Total                         1094      1240      1066    706     0
    (% Fs=48.0kHz)                18%       6%        3%      2%      0%
    STREAM fs=16000               Inst      Inst      DM0     DM1     PM
    STACK                          -         -        68      0       0
    FRAMEWORK                     127       141       153     0       0
    FIR3_2                        60        32        192     194     0
    FIR4_2                        60        32        192     2       0
    FIR5_2                        60        30        192     194     0
    FIR6_2                        60        30        192     194     0
    UpSampling2                   12        20        2       0       0
    Level2_17                     13        14        14      0       0
    DownSampling1_2               10        14        0       4       0
    Level2_16                     13        13        14      0       0
    Add1_16                       8         8         0       2       0
    Total                         423       334       1019    590     0
    (% Fs=16.0kHz)                3%        2%        3%      2%      0%
    STREAM fs=8000                Inst      Inst      DM0     DM1     PM
    STACK                          -         -        68      0       0
    FRAMEWORK                     140       156       155     0       0
    UpSampling1_2                 16        26        2       0       0
    BlockInput1                   26??      26        0       16      0
    BlockInput7                   26??      26        0       16      0
    BlockOutput1                  22?       22        0       18      0
    BlockOutput3                  22?       22        0       18      0
    (? Call instruction present, actual cycle count may differ.)
    Total                         252       278       225     68      0
    (% Fs=8.0kHz)                 1%        2%        1%      1%      0%
    BLOCK fs=8000   size=64       Inst      Inst      DM0     DM1     PM
    MALLOC                         -        216       348     1408    0
    FRAMEWORK                     116       136       153     0       0
    FRNR4                         53660?    351       4508    8       0
    FRNR1                         53660?    351       4508    8       0
    FRNR3                         53660?    351       4508    8       0
    FRNR2                         53660?    351       4508    8       0
    Synthesis Window2_6           141?      31        129     68      0
    Synthesis Window2_4           141?      31        129     68      0
    Synthesis Window2_5           141?      31        129     68      0
    Synthesis Window2_7           141?      31        129     68      0
    Analysis Window2_4            140?      27        132     4       0
    Analysis Window2_5            140?      27        132     4       0
    Analysis Window2_7            140?      27        132     4       0
    Analysis Window2_6            140?      27        132     4       0
    IFFT2                         1436?     12        0       4       0	using: Complex IFFT Sub DM1128
    IFFT3                         1436?     12        0       4       0	using: Complex IFFT Sub DM1128
    FFT3                          1368?     12        0       4       0	using: Complex FFT Sub DM1128
    FFT4                          1368?     12        0       4       0	using: Complex FFT Sub DM1128
    FFT2                          1368?     12        0       4       0	using: Complex FFT Sub DM1128
    IFFT4                         1436?     12        0       4       0	using: Complex IFFT Sub DM1128
    IFFT1                         1436?     12        0       4       0	using: Complex IFFT Sub DM1128
    FFT1                          1368?     12        0       4       0	using: Complex FFT Sub DM1128
    BlockInput3                   2         2         0       4       0
    BlockInput5                   2         2         0       4       0
    BlockInput4                   2         2         0       4       0
    BlockInput2                   2         2         0       4       0
    BlockOutput4                  2         2         0       0       0
    BlockOutput2                  2         2         0       0       0
    BlockOutput5                  2         2         0       0       0
    BlockOutput6                  2         2         0       0       0
    Subroutines called:
    Complex FFT Sub DM1128              -        418       3       0       0
    Complex IFFT Sub DM1128             -        471       0       0       0
    Total                         227112    2989      19580   1776    0
    (%)                           10%       13%       48%     5%      0%
    Instructions Per-Block-Frame (total/blocksize):  3549
    Project1.dspproj
  • Hello Shahar123,
    I loaded up the projects and tested them. The problem with the Project1 is that it uses custom DLLs and I do not have the custom DLLs. How did you get past that? Did you copy the DLLs and add them into Rev 4.6?
    Are you running this on an evaluation board or your own hardware?
    Dave T
  • Hello Dave
    We purchased function of Noise reduction from Analog and added manually for sigma studio Rev 4.6.
    We have window 10 on the computer.
    Thanks
    Shahar
  • Shahar and Menashe,
    Project1 appears to be corrupted. It does not open correctly in v4.5. Have you opened this with v4.6 and then saved it? Do you have the project that worked with v4.5?
    Ken
