I have a problem with a project for ADAU1466. I have detected a latency difference between two channels of 1 sample. I have been reducing my schematic until I find the problem and I have found it in the "T Connection" block.
If I make a direct connection from input to output, the L and R channels have the same latency, as can be seen in this screenshot. I have the same signal on both inputs.
If I put a "T Connection" and connect the two outputs to the same block I have a difference of 1 sample in one of the outputs. It can be seen in the screenshot.
Do you know anything about this?
Regards
Carlos
Output channel 1 sample latency
[edited by: carlos@lynx at 3:19 PM (GMT -4) on 16 May 2022]
