Sport config in 21571
    When I use sport in 21571 to communicate with ADAU1452 or other DSPs, some problems about clk and data config confused me.
    In TDM16 mode,  I use 21571 to send datas to 1452, my config is below
    adi_sport_ConfigData(hSport3B, ADI_SPORT_DTYPE_SIGN_FILL, 31u, false, false, false);
    adi_sport_ConfigClock(hSport3B, 0u, false, true, false);
    adi_sport_ConfigFrameSync(hSport3B, 0u, true, false, true, true, false, false);
    adi_sport_ConfigMC(hSport3B, 1u, 15, 0u, false);
    As my understand, I think this config sport to I2S , LRCLK negative , BCLK negative.
    So I config 1452 SDATA_IN to TDM16, I2S , LRCLK negative , BCLK negative. Then in my test I can receive correct audio in 1452.
    But when I use 1452 to send datas to 21571, remain the config in 21571. If I still use the same config in 1452, the audio receive in 21571 will become noise. In my test, I must change the BCLK in 1452 to positive, then I can get correct audio. I don't know why the config in 21571 and 1452 need to be different., if I was wrong before what's the correct config ?
    Another problem is if I config in TDM8, is it same to TDM16?
    on Apr 5, 2021 2:48 PM
    Moved to appropriate community
    on Apr 5, 2021 7:48 PM
    Hello Foster,
    Santha moved this over to the SigmaDSP part of the forum because of your mention of the ADAU1452. I do not think the issue has to do with the 1452. but I can help out some.
    Can you describe what devices are the clock master and which one is the clock slave? This is important for both the serial port inputs and output of the ADAU1452. Supplying the SigmaStudio project file would be handy to see how it is setup.
    What is the sample rate you are using?
    Now making an assumption that you are operating at 48kHz fs and you mentioned TDM16. The frequencies of the data and bit clock are rather high and so PCB design, layout and transmission line design become important. So PCB layout and design may be part of this issue.
    I will wait until I hear back before going further.
    Dave T
  • Hello Dave,
    I agree it's not the issue of 1452, I think it's 21571 or the PCB problem, since I'm new to SHARC, so I can't make sure where make the problem.
    I have tested when I use a1452 to send to another 1452, whatever config I set in sigmastudio of SDout, the same set copy to the SDin of another 1452, it works well. However in 21571, the config is diffrent. Recently I read the hardware refference of 21571, I find that 21571 samples half bit later than the drive signal ,maybe this is why I need to change the polarity of BCLK.
    The config is not really the problem confuse me, since I can get the right datas now changing BCLK. What trouble me is that my system is not stable. If I use 21571 as master in TDM8, datas are from 1452 to 21571, noise occur everytime. So I change to 1452 as clock master, then it is good most time, but noise still occur sometimes.
    Do you have some suggestions on how to locate my problem?
    on Apr 6, 2021 2:14 AM in reply to Foster
    Hello Foster.
    You still did not answer my question of who is the master. So I will explain why I was asking. I was trying to avoid explaining all this if it was not needed.
    In a transmission line to transmit the data it comes down to the timing of the bitclock and the data.
    It is correct that the transmitting device will change the data on the start of the bit and the receiving device should sample half a bit clock later. So if the bit starts with the bitclock falling then the receiving device will sample on the rising edge. This gives time for the sending device to change the output to the level of the new bit. Then it does take time for this new level to travel down the PCB trace to get to the receiving device. Just like if I were to toss a tennis ball to you from across the room and you clasp your hand at exactly the same time I release the ball you will miss it every time. You wait for it to arrive.
    This is the timing margin. Now there is another wrinkle in this. By far the best way to get the most timing margin is to have the device that is sending the data be the device that it driving the bit clock and frame (LRCLK) clock.
    If the sending device is a clock slave then the bitclock is coming from the receiving device. So the receiver changes the bitclock level. This change has to travel down the PCB trace to get to the sending device. Then the sending device has to recognize this clock edge and then internally signal the data driver to change to the next bit and send that out. Then the new data bit has to travel back to the receiving device. The turn around time inside a device as a slave is a long time. Look at table 9 in the newest rev in the ADAU1452 datasheet. Look at the tSODS specification. In this newest revision I went through a lot of trouble to detail this specification at different drive settings. Because the 35ns is too slow for high rates of bit clock.
    So if you are running the serial output port as a slave then the data is probably arriving too late and missing the timing of half the bit clock rate. At a bit clock rate of 12.288MHz you have ~40ns for the data to get there. That is most likely on the edge but if you are using a 24MHz bit clock then it WILL be too late. The ADAU1452 drive strength setting will help but the clock drive strength also needs to be increased. If you operate as a master this tSODS specification does not apply.
    Then there is the PCB issues. Long lengths of clock lines can be a problem but if the termination of the transmission lines is poor then there will be reflections that will cause errors as well.
    So look at drive strengths, who is the clock master and your PCB layout and you should be able to solve this issue.
    Dave T
  • Hello Dave,
    Thank you for explaining to me in detail. No one talked about this issues with me before, it helps me a lot.
    In part of my system, 1452  send datas to 21571, both TDM16 and TDM8 is used. In TDM16 mode, master clock is another chip out of 1452 and 21571, 1452 send datas in BCLK rising edge and 21571 receive in falling edge. In TDM8 mode , 1452 is clock master, I set the same config, noise comes sometimes.
    I have used 1452 for a long time , in my projects ago, it's 1452 send to another 1452, I always set the same falling edge of BCLK in both 1452s,  there is no problem before. But now after you explained, it means I was wrong before, I need to set the Tx 1452 as master and  SDATA_OUT BCLK negative which means sending datas in falling edge of BCLK . Then make the Rx 1452 as slave and SDATA_IN BCLK positive which means receive datas in rising edge. Is my understanding ture?
    As you said, set 1452 drive strength can help, I use the default config as the picture shows.config
    There are BCLK, LRCLK, SDATA pins, do I need to set all three pins? Besides strength , if the setting of pull-down and slew rate will help too?
    If I add a drive chip in my PCB, is it better than config in 1452?
    In my PCB, between 1452 SDATA_OUT pin and 21571 DAI pin ,there is a 100 ohm resister, will it make data transfer slower?
