ADAU1452 S/PDIF 192KHz support issue?
Hi Sir,
I am test the S/PDIF input function and the input sample rate will be 48~192KHz, But if we set the sample rate above the 96KHz.
The audio will include the noise , I check with the spec from the datasheet as below shown. it only can support 96KHz sample rate from S/PDIF.
from the ADAU1452 EVB user guide , it mentioned , the S/PDIF can support 192KHz , Can you help to confirm , which one is correctly?
thanks for your help.
