Ultra-strange filter problem..
Hi!
While evaluating the second revision of my DSP board, I noticed some super strange behaviour that is caused by a 2nd order lowpass filter.
See for yourself.
This is basically what you would expect. This uses a single-precision, no slew, 2nd order LP filter set to 2000Hz. The measurement below is not meant to show the filter function, rather the device output. You'll see what I mean when we get to the problem.
Now, this is the exact same thing, but with a double precision filter (same type of course):
What the hell?
It gets even stranger..
This is the two filters above in one design, with a switch to easily compare them (at least that was my approach to troubleshooting the issue)
This results in this:
What is this ? It makes zero sense.
The switch doesn't change the behaviour either.
Thankful for any help.
Noel
[edited by: nneu at 2:35 AM (GMT 0) on 14 Jan 2020]
