No way to use ADAU1701 Class-D amplifier
I´m really disapointed with the performance of the outputs DAC0 and DAC1. No sound at all!
I´m using the Evaluation Board UG-072. It should be easier to get a simple sound.
Do I have to set up anything?
Thanks
    •  Super User
    on Aug 11, 2019 12:01 AM
         The UG-072 document describes the ADAU1401ABEZ evaluation board, a 6" x 6" board with many setup options / jumpers yet with no Class-D amplifier.  Its four DAC outputs have active op-amp filters with 600 ohm output impedance -- these outputs can drive an external amplifier but you'll get little or no sound with headphones.  The much smaller ADAU1701MINIZ board does include an on-board SSM2306  2-watt Class-D amplifier wired to DACs 0,1.  Its speaker outputs are available at the green terminal board.   DACs 2,3 output to a headphone jack with sufficiently low impedance to drive sensitive headphones or an external amplifier.
        Examining your screenshot, I cannot see what signal you have feeding the VCO.  I'd suggest testing with a straight sine oscillator instead -- one less thing to go wrong.  If your ADAU1401ABEZ board is new out of the box its switches and jumpers should already be set to get output from the DACs -- but if not, carefully go over the settings shown on page 3 of document UG-072.
        If you're actually using the ADAU1701MINIZ board and cannot get output from its Class-D amplifier via the two speaker outputs on its green terminal board -- the SSM2306 is off by default, you need to  enable it.  To do this, first go to Hardware Configuration / 170x/140x Register Control and set MP7 to Output GPIO:
    Then add a nonzero DC source feeding GPIO output 7, as shown below:
         Bob
    on Aug 14, 2019 8:34 PM
    Hello oceam2,
    You have to dig a little on our web site to find this but here is the user guide for the MiniZ
    https://www.analog.com/media/en/technical-documentation/evaluation-documentation/EVAL-ADAU1701MINIZ.pdf
    Dave T
