ADAU 1452 MasterSPI not working
I´m trying to get my program from SigmaStudio 4.4 to the EEPROM connected to my ADAU1452.
The DSP is connected via the I²C-Slaveport to the PC.
The EEPROM (25AA1024) is connected via SPI-Masterport
Selfboot is turned off (LOW).
ADDR0 & ADDR1 are also Low.
schematic
The connection to the DSP works fine. I can read and write all the registers.
But if I try to use the "Write Latest Compilation through DSP" funktion, it doesnt work.
The I2C-connection is working fine but the SPI-comunication doesnt start (no movement on the Master SPI pins)
Supply voltage is Stable.
Did I forget any configuration?
Settings in SigmaStudio 4.4
Thanks in advance
