the command "Check Last Compilation vs E2PROM" is crashing
Everything is working fine with my project on ADAU1701
But I have an issue with the command "Check Last Compilation vs E2PROM".
It crashes USB communications with error message "A USB communication failure has occured".
I need to reset the iUSB interface by disconecting/conncting USB cable for SigmaStudio 3.16 to recover from this error.
SigmaStudio 4.2 is able to recover just by fresh use of "Compile Link Download" F7.
Same time I am able to see (read back from memory) the content of EPROM by use of "Read E2Prom to Display" in "Hardware Configuration/ IC2 - Win E2Prom Loader" tab.
And it is same as .hex file loaded by use of "Display file".
What is wrong with "Check Last Compilation vs E2PROM" if communications are OK to read back from EPROM?
Second thing, the command (button) "Upload E2Prom To File" is not working without any kind of response. Any advice?
Raimonds
Second issue added
[edited by: Raimonds at 1:07 PM (GMT 0) on 18 Dec 2018]
