ad7928 connect  ADSP21369 with spi
hello friends
i design a system using ad7928 collect the data.
now the spiclk , mosi and cs has signals,but the miso cann't catch the signal.it always high.
below is my functions.
    SRU(SPI_MOSI_O,DPI_PB01_I)      //Connect MOSI to DPI PB1.
    SRU(DPI_PB02_O, SPI_MISO_I)     //Connect DPI PB2 to MISO.
    SRU(SPI_CLK_O, DPI_PB03_I)      //Connect SPI CLK to DPI PB3.
    SRU(SPI_FLG0_O, DPI_PB04_I)     //Connect SPI FLAG3 to DPI PB4.
    // Tie pin buffer enable from SPI peipherals to determine whether they are
    // inputs or outputs
    SRU(SPI_MOSI_PBEN_O, DPI_PBEN01_I);
    SRU(SPI_MISO_PBEN_O, DPI_PBEN02_I);
    SRU(SPI_CLK_PBEN_O, DPI_PBEN03_I);
    SRU(SPI_FLG0_PBEN_O, DPI_PBEN04_I);
void SPITransmit(int val)
     *pTXSPI = val;
     Delay(10);
    //Wait for the SPI to indicate that it has finished.
    while (1)
        if (*pSPISTAT & SPIF)
            break ;
    Delay (10) ;
void adcommand()
       8e5e9a042abdb7130e1538d46d9df541.htmlSPITransmit(0xff);
     SPITransmit(0xff);
       SPITransmit(0xff);
     SPITransmit(0xff);
    SPITransmit(0x3f);
     SPITransmit(0x08);
//ad7928
void SPIisr (void)
     int ad_temp=0,temp=0,temp1,ad_temp1=0;
    temp++;
    SPITransmit(0x3f);
    SPITransmit(0x00);
    //ad_temp = ;
//    ad_temp1= *pTXSPI;
    ad_temp = *pRXSPI;
now i can go into the interrupt,but the value of  *pRXSPI always  zero, but the pin is high!!!!!
thanks
tracy
Parents
    on Aug 2, 2018 4:21 PM
    Thank you,
    EZ Admin
Reply
    Thank you,
    EZ Admin
Children
No Data
