Hi everybody,
i am using a ADSP-21489 EZ-Board. I took the C Block-Based Talkthru 48 kHz example and tried to integrate two sample rate conversions.
What I'd like to do:
- take 48 kHz samples from the 4 RCA jacks, decimate the sampling frequency to 8 kHz
- my existing software takes the 8 kHz samples, outputs samples with 16 kHz
- upsample those to 48 kHz, output to the 8 RCA jacks
I tried to use the SRC1 unit between the ADC and SPORT1 (Rx) and SRC0 between SPORT0 (Tx) and DAC, but sadly I wont get any output...
My SPORT control registers:
//12.288 MHz SCLK from AD1939
*pDIV1 = 0x05FF0000;
*pDIV0 = 0x02FF0000;
// sport1 control register set up as a receiver in MCM
// externally generated SCLK1
*pSPCTL1 = SCHEN_A | SDEN_A | SLEN24 | IMFS;
// sport0 control register set up as a transmitter in MCM */
// sport0 control register, SPCTL0 = 0x000C01F0 */
*pSPCTL0 = SCHEN_A | SDEN_A | SPTRAN | SLEN24 | IMFS;
// sport1 receive & sport0 transmit multichannel word enable registers
*pSP1CS0 = 0x0000000F; // Set to receive on channel 0-3 on SPORT1
*pSP0CS0 = 0x000000FF; // Set to transmit on channel 0-7 on SPORT0
// sport1 & sport0 receive & transmit multichannel companding enable registers
// no companding for our 4 RX and 8 TX active timeslots
// no companding on SPORT1 receive
// no companding on SPORT0 transmit
*pMR1CCS0 = *pMT0CCS0 = 0;
// SPORT 0&1 Miscellaneous Control Bits Registers
// SP01MCTL = 0x000000E2, Hold off on MCM enable, and number of TDM slots to 8 active channels
// Multichannel Frame Delay=1, Number of Channels = 8, LB disabled
*pSPMCTL0 = NCH7 | MFD1;
*pSPMCTL1 = NCH7 | MFD1;
// Enable multichannel operation (SPORT mode and DMA in standby and ready)
*pSPMCTL0 |= MCEA;
*pSPMCTL1 |= MCEA;
SRU Settings:
SRU(DAI_PB07_O, SPORT1_CLK_I); // DAIP17 (RSCLK1) to SPORT1 CLK (CLK)
SRU(DAI_PB07_O, SPORT0_CLK_I); // DAIP7 (RSCLK1) to SPORT0 CLK (CLK)
// Route SPI signals to AD1939 Control Port.
SRU(SPI_MOSI_O, DPI_PB01_I); //Connect MOSI to DPI PB1.
SRU(DPI_PB02_O, SPI_MISO_I); //Connect DPI PB2 to MISO.
SRU(SPI_CLK_O, DPI_PB03_I); //Connect SPI CLK to DPI PB3.
SRU(SPI_FLG0_O, DPI_PB04_I); //Connect SPI FLAG0 to DPI PB4.
// Tie pin buffer enable from SPI peipheral to determine whether they are
// inputs or outputs
SRU(SPI_MOSI_PBEN_O, DPI_PBEN01_I);
SRU(SPI_MISO_PBEN_O, DPI_PBEN02_I);
SRU(SPI_CLK_PBEN_O, DPI_PBEN03_I);
SRU(SPI_FLG0_PBEN_O, DPI_PBEN04_I);
// Connect SRC clock and framesync
SRU(DAI_PB07_O, SRC1_CLK_IP_I);
SRU(DAI_PB07_O, SRC0_CLK_OP_I);
SRU(DAI_PB08_O, SRC1_FS_IP_I);
SRU(DAI_PB08_O, SRC0_FS_OP_I);
SRU(SPORT1_CLK_O, SRC1_CLK_OP_I);
SRU(SPORT0_CLK_O, SRC0_CLK_IP_I);
SRU(SPORT1_FS_O, SRC1_FS_OP_I);
SRU(SPORT0_FS_O, SRC0_FS_IP_I);
// Connect SRC1 between ADC -> Sport1, SRC0 between Sport0 -> DAC
SRU(DAI_PB05_O, SRC1_DAT_IP_I); //DAIP5 (DR1PRI) to SRC1 input
SRU(SRC1_DAT_OP_O, SPORT1_DA_I); //SRC1 output to SPORT1 DA (RX)
SRU(SPORT0_DA_O, SRC0_DAT_IP_I);
SRU(HIGH, PBEN12_I);
SRU(SRC0_DAT_OP_O, DAI_PB12_I); //SRC0 output to SPORT0 DA (TX)
SRC Settings:
*pSRCCTL0 =SRC0_SMODEIN1 | SRC0_SMODEOUT1 | SRC1_SMODEIN1 | SRC1_SMODEOUT1; // TDM In/out, 24bit
// Enable SRC in a different cycle than setting the configuration
*pSRCCTL0 |= SRC0_ENABLE | SRC1_ENABLE;
What am I missing?
Thanks in advance,
lyman
