ADSP21478 Control ADAU1328 PLL lock indicator not locked Question
Hi I'm Sean
I use custom board for ADSP21478 .
I try to control ADAU1328.
But the PLL lock indicator register respond to "0".
How can I double check program  problem or Hardware problem?
The program is stop to the LockTest,becasue the PLL lock indicator register not respond to "1"
    LockTest = Get1939Register(0x1, ad1939_cs);
    while (!(LockTest & AD1938_PLL_LOCK))
        LockTest = Get1939Register(CLKCTRL1, ad1939_cs);
        LockCount++;
My custom Board codec use Quartz Crystal 12.288MHZ.
and the ADSP21478 use Quartz Crystal 25MHZ.
My CCLK is 200MHZ.
I use AD1939 Example code changes SPI CLK  Frequency is 500kHZ.
My Program are as follows
/* Setup the SPI parameters here in a buffer first */
unsigned char ConfigParam1939 [] = {
            (AD1939_ADDR), DACMUTE, 0x00,
            (AD1939_ADDR), CLKCTRL0, DIS_ADC_DAC | INPUT256 | PLL_IN_MCLK | MCLK_OUT_OFF | PLL_PWR_DWN,
            (AD1939_ADDR), CLKCTRL1, DAC_CLK_PLL | ADC_CLK_PLL | DIS_VREF,
            (AD1939_ADDR), DACCTRL0, DAC_FMT_I2S | DAC_BCLK_DLY_1 | DAC_SR_96K,
           (AD1939_ADDR), DACCTRL1,  DAC_BCLK_SLAVE| DAC_LRCLK_SLAVE  | DAC_CHANNELS_2 | DAC_LATCH_MID, //Ddebug
            (AD1939_ADDR), DACCTRL2, DAC_WIDTH_24,
            (AD1939_ADDR), ADCCTRL0, ADC_SR_96K,
            (AD1939_ADDR), ADCCTRL1, ADC_LATCH_MID | ADC_FMT_I2S | ADC_BCLK_DLY_1 | ADC_WIDTH_24,
          (AD1939_ADDR), ADCCTRL2, ADC_BCLK_SRC_INTERNAL | ADC_BCLK_MASTER | ADC_CHANNELS_2 | ADC_LRCLK_MASTER  | ADC_LRCLK_FMT_50_50|ADC_LRCLK_POL_NORM|ADC_BCLK_POL_NORM, // NDdebug
          (AD1939_ADDR), DACVOL_L1, DACVOL_MAX,
            (AD1939_ADDR), DACVOL_R1, DACVOL_MAX,
            (AD1939_ADDR), DACVOL_L2, DACVOL_MAX,
            (AD1939_ADDR), DACVOL_R2, DACVOL_MAX,
            (AD1939_ADDR), DACVOL_L3, DACVOL_MAX,
            (AD1939_ADDR), DACVOL_R3, DACVOL_MAX,
            (AD1939_ADDR), DACVOL_L4, DACVOL_MAX,
            (AD1939_ADDR), DACVOL_R4, DACVOL_MAX,
            (AD1939_ADDR), CLKCTRL0, DIS_ADC_DAC | PLL_IN_MCLK | MCLK_OUT_OFF | INPUT256 | PLL_PWR_UP,
            (AD1939_ADDR), CLKCTRL0, ENA_ADC_DAC | PLL_IN_MCLK | MCLK_OUT_OFF | INPUT256 | PLL_PWR_UP,
unsigned char AD1938_Regs_Read[sizeof(ConfigParam1939) / 3];
unsigned char B_Test[sizeof(ConfigParam1939) / 3];
volatile int spiFlag ;
// Set up the SPI port to access the AD1939
// Call with SPI flag to use
void SetupSPI1939(unsigned int SPI_Flag)
    // Configure the SPI Control registers
    // First clear a few registers
    *pSPICTL = (TXFLSH | RXFLSH) ;
    *pSPIFLG = 0;
    // Setup the baud rate to 500kHz
    //*pSPIBAUD = 100;
    *pSPIBAUD = 100;
    // Setup the SPI Flag register using the Flag specified in the call
    *pSPIFLG = (0xF00|SPI_Flag);
    // Now setup the SPI Control register
    *pSPICTL = (SPIEN | SPIMS | WL8 | MSBF | TIMOD1 | CLKPL | CPHASE |SMLS|GM);//
// Disable the SPI Port
void DisableSPI1939(void)
    *pSPICTL = (TXFLSH | RXFLSH);
// Send a word to the AD1939 via SPI
// Call with the AD1939 address, register address, register data,
// and SPI flag to use
void Configure1939Register (unsigned char rwaddr,unsigned char regaddr,unsigned char regdata, unsigned int spiselect)
    int i,j;
    unsigned char val[3];
    SELECT_SPI_SLAVE(spiselect);
    val[0]=WR(rwaddr);
    val[1]=regaddr;
    val[2]=regdata;
    for(i=0;i<3;i++)
        j=0;
        *pTXSPI = val[i] ;
        //Delay(136);
        //Wait for the SPI to indicate that it has finished.
        while ((*pSPISTAT & TXS))
        {j++;}
    j=0;
    while (!(*pSPISTAT & SPIFE))
    {j++;}
    Delay(13);
    DESELECT_SPI_SLAVE(spiselect);
// Receive a register setting from the AD1939
// Call with the register address, and SPI flag to use; returns register data
unsigned char Get1939Register (unsigned char regaddr, unsigned int spiselect)
    int i,j;
    unsigned int tmp;
    val[0]=RD(AD1939_ADDR);
    val[1]=regaddr;
    val[2]=0;
    for(i=0;i<3;i++)
        j=0;
        *pTXSPI = val[i] ;
        {j++;}
    j=0;
    while (!(*pSPISTAT & SPIF))
    {j++;}
    {j++;}
    Delay(13);
    tmp = *pRXSPI;
    return tmp;
// Set up all AD1939 registers via SPI
int LockCount = 0;
unsigned int LockTest;
void Init1939viaSPI(int codec)
    int configSize = sizeof(ConfigParam1939);
    int j=0 ;
    unsigned char tmpA[sizeof(ConfigParam1939) / 3];
    unsigned int ad1939_cs;
          int i=0;
        ad1939_cs = DS0EN;
    //Set up AD1939
    SetupSPI1939(ad1939_cs);
    //Write register settings
    for(i = 0; i < configSize-6; i+=3)
        Configure1939Register(ConfigParam1939[i], ConfigParam1939[i+1], ConfigParam1939[i+2], ad1939_cs);
        Delay(272);
        //Read back register settings for debugging
        AD1938_Regs_Read[j++] = Get1939Register(ConfigParam1939[i+1], ad1939_cs);
        Delay(272);
        LockCount++;
    for(i = configSize-6; i < configSize; i+=3)
        Delay(272);
        Delay(272);
    DisableSPI1939();
//Delay loop
void Delay(int i)
    for(i ; i > 0; --i)
        asm("nop;");
My SPI protocol are as follows
SPI CLK is 500KHZ
Period is 2us
+Width is 998.ns
-Width is 1us
TCLH is 160ns
TLCS is 2.42us
TCCP is 1.82us
    on Jan 7, 2013 8:09 PM
    Are you able to read back any registers to confirm that they have been programmed with your settings? It looks from your settings that you are putting the ADC into Master mode; do you see any clock activity at the ALRCLK, ABCLK or ASDATAx port?
    Coleman
  • I can read back registers .
    I use Debug mode by HPUSB-ICE
    I can read back any registers ,but PLL lock indicator register not respond to "1"
    and then I don't see any clock activity at the ALRCLK, ABCLK or ASDATAx port.
    My Registers Parameters  are as follows
    on Jan 19, 2013 3:04 AM
    To confirm, with the settings you show above, and a valid MCLK signal driving the MCLKI pin, you are not seeing any activity on ALRCLK or ABCLK? Your settings have put the ADC in Master Mode, and if everything is powered properly in the IC, you should see clocks coming out of the audio port.
    If you read Register 1 (PLLClockCont1) bit 3, you do not see a '1?'
    By the way, your setting of Register 16 (ADCCont2) bit 7 to 'Internally generated' is useful in the case where you are trying to reduce the EMI radiation and do not want the ABCLK port to drive BCLK out; you are relying on good integrity and precise internal clocks for the BCLKs to align between ports. Having not seen your schematic, I would generally recommend that this be left in default as ABCLK pin.
    Coleman
    on Aug 2, 2018 4:47 PM
    Thank you,
    EZ Admin
