DSP: 21489
Audio Codec:AD73322L
Operation mode: Using AD73322L generate bit clock,frame sync.
Question: The DMA is work,but no interrupt generate.When using Internal clock the DMA interrupt enter. Why & How to do?
Thanks.
Init code:
section("seg_dmda") unsigned short RxBlock_A0[64];
section("seg_dmda") unsigned short RxBlock_A1[sizeof(RxBlock_A0)];
//Set up the TCBs to rotate automatically
int TCB_RxBlock_A0[4] = { 0, sizeof(RxBlock_A0), 1, 0};
int TCB_RxBlock_A1[4] = { 0, sizeof(RxBlock_A0), 1, 0};
*pSPCTL1 |= (SLEN16 | FSR | DIFS | CKRE | LFS | SDEN_A | SCHEN_A);
TCB_RxBlock_A0[0] = (unsigned int) TCB_RxBlock_A1 + 3 - OFFSET + PCI ;
TCB_RxBlock_A0[3] = (int) RxBlock_A0 - OFFSET ;
TCB_RxBlock_A1[0] = (unsigned int) TCB_RxBlock_A0 + 3 - OFFSET + PCI ;
TCB_RxBlock_A1[3] = (int) RxBlock_A1 - OFFSET ;
*pCPSP1A = (unsigned int)TCB_RxBlock_A0 - OFFSET + 3;
*pSPCTL1 |= ( SPEN_A);
