FFT Accelerator
The user inquired about the FFT function similar to the radix-2 complex floating-point FFT butterfly implemented in the FFT accelerator. The final answer indicates that the cfftf library function was used to obtain the core performance numbers, as detailed in the ADSP-214xx Hardware Reference Manual on page 7-80.
Hi ,
In the Manual it is described that FFT accelerator implements radix-2 complex floating-point FFT butterfly .
Which FFT function is similar to that of that FFT accelerator.   There are CFFT , CFFTF which will it be .
Thanking you
With best regards and wishes
