Generating ADSP-21363 SPI interrupt in DMA
I have a following request.
Could ADSP-21363 generate an interrupt from SPI which are working in DMA mode only after transmitting of 3 bytes to the slave?
By default interrupt is generated only after putting data into Tx FIFO. I just would like to manipulate Chip Select signal only after getting the interrupt. VDSP++ is used.
Could you please recommend something? Thank you in advance.
Ivan
