how can i write/read two bytes to the TWI interface using ADSP21489?
Hi  everyone
                I ues the TWI interface of SHARC reading the tempereture sensor.Now, i use the example of the Power_On_Self_Test  and  i can write/read one byte data to the TWI interface. But i can not  write/read two bytes to the TWI interface.
              MY slave is the tmp112,i read the datasheet, the time diagram is below.
//THE CODE
void I2C_Master_Write (unsigned int data, unsigned int address)
/* setup flag */
g_write_pend = 1;
/* write address to the 8-bit TX fifo */
*pTXTWI8 = address;
/* enable master transfer complete and TX FIFO service interrupts */
*pTWIIMASK = TWIMCOM | TWITXINT;
/* setup for 2 data bytes, master enable, master TX */
*pTWIMCTL = TWIDCNT2 | TWIMEN;
/* wait for data */
while ( g_buff_empty != 1 )
/* write data to the 8-bit TX fifo */
*pTXTWI8 = data;
/* reset flag */
g_buff_empty = 1;
/* wait for write to complete */
while( g_write_pend == 1 )
*pTXTWI8 = data;
/* reset flag */
g_buff_empty = 1;
int Read_TWI_Register(int address)
int temp; /* temporary int */
/* setup flags, to read we do both write and read */
g_write_pend = 1;
g_read_pend = 1;
*pTXTWI8 = address;
/* enable master transfer complete interrupt */
*pTWIIMASK = TWIMCOM;
/* setup for 1 data byte, master enable, master TX */
*pTWIMCTL = TWIDCNT1 | TWIMEN;
/* setup for 1 data byte, master enable, master RX */
*pTWIMCTL = TWIDCNT1 | TWIMEN | TWIMDIR;
/* wait for read to complete */
while( g_read_pend == 1 )
/* read data from the 8-bit RX fifo */
temp = *pRXTWI8;
return temp;
catching  the wave from the OSC
the write
the read
hope someone can give me some advice,thanks.
        jack
attachments.zip
  • Hi Jack,
    Sorry for the delayed response. Let me work on this and get back you shortly.
    Jithul
  • The TWI FIFO buffer is configured as a 1-byte-wide, 2-deep transmit FIFO buffer and a 1-byte-wide, 2-deep receive FIFO buffer. The TWI 16-bit FIFO transmit register (TXTWI16) and TWI 16-bit FIFO receive register (RXTWI16) holds a 16-bit data value written into / read from the FIFO buffer respectively. Although peripheral bus reads are 32 bits, a read access to the TXTWI16/RXTWI16 register can only access two receive data bytes from the FIFO buffer. To reduce interrupt output rates and peripheral bus access times, a double-byte receive data access can be performed. Two data bytes can be read, effectively emptying the receive FIFO buffer with a single access.
    You can program the  the TWIFIFOCTL register to indicate if transmit (or receive) FIFO buffer interrupts should occur with each byte transmitted (received) or with each 2 bytes transmitted (received). So could you please check with 16-bit standard mode transfer and see if it meets your requirement.
    Thank you,
    EZ Admin
  • Hello  jack,
     I have a similar issue, I am not able to read the temperature values from the tmp112 sensor (It shows the value as 0). My read and write function are similar to yours and I have made the changes suggested by admin. Could you tell me how are communicating with the sensor?
    Thank you.
    Apologies for the delay.
    1. Do you have check with 16 bit standard mode transfer?
    2. Are you able to read / write with single byte data without any issue?
    Anand Selvaraj.
