ADZS-SC584-EZLITE  Support
Dear Ken,
thank you for all this valuable information. I have some more questions:
1) Evaluation Board questions:
Checking the ADZS-SC584-EZLITE I´ve seen in the schematics there are two stereo audio inputs that can be switched using a ADG774A MUX.
I understand these connectors are used for connecting a line level device to test all the processing developed in the Evaluation board. Is this correct? We would like to use simple line level audio at a first sight to do the inital testing.
On the other hand, is this evaluation kit capable of connecting a dynamic or condenser microphone? If not, is there additional HW for this type of connections?
2) Software questions:
We will first use SigmaStudio to develop the DSP processing code graphically. If I have undertand it, once the SigmaStudio processing code is generated by SigmaStudio then CrossCore Embedded Studio will be used to program the ADPS-CS58. Is this correct?
About the crosscore embedded studio licensing: We will use only use license in one unique PC. I understand we could use the AD-CCES-NODE-1 license for ever and the AD-CCES-MNT-N1 anual maintenance license. This would take an initial price of 995$+199$. Then, each year we would only have to pay the 199$ maintenance licence. Is this correct? I understand this can be done once the 6 months CCES ends.
Is the Linux Addin free? I can´t see the price.
We would like to mount a web server on the device so we can access and control de device using a web browser in any platform. Could the ARM-5 integrated in the ADSP-CS58 be capable of this and also control the DSP processing? Do you recommend additional MCU to control this Web Server feature?
3) I would like to know addtional resources on DSP audio processing using these tools. Maybe there´s a deedicated forum for this chip family and software tools.
Thank you very much in advance for your answer.
Best,
Julian
Parents
    on Dec 13, 2017 2:31 AM over 2 years ago
    >> yes, your understanding is correct. You can connect maximum two analog audio input pairs via RCA connectors and process it via DSP and provide 4 pairs of audio output.
    Do you have any specific condenser microphone that you would like to use?
    >> You might post this query in the SigmaStudio for SHARC community, they would help you better.
    >>A user may install and use new versions of their product, and updates to it, only if they have an active subscription. If you try to install a newer version of CCES update, when your subscription has expired, it may throw an error. Subscription starts when a full license is activated, and ends one year from that date unless a maintenance license is purchase and activated, renewing the subscription period for a further year.
    However this does not mean that you cannot use the License Serial number any more.  In fact, it is a Permanent license. If you see any license expiration message, you may ignore the message and continue to use CCES.
    For more information about License Expiration and Subscription please refer the following FAQ .
    https://ez.analog.com/docs/DOC-2410
    >> You might post this query in the Linux for ADSP-SC5xx processors  community, they would help you better.
Reply
Children
No Data
