Bootloader Project for ADSP-21488
We're using ADSP-21488 in one of our products. We wanted this processor to boot from the Flash. In our prototype board we connected the SPI lines as follows:
DPI_P01 -> SPI0_MISO
DPI_P02 -> SPI0_CLK
DPI_P03 -> SPI0_MOSI
We made sure that the flash has the right content (proper loader), but the DSP was not booting from the flash. When we probed the SPI lines while powering-up, we found out that the SPI clock is appearing on DPI_P03. In the hardware reference manual we found out that the default routing is as follows:
DPI_P01 -> SPI0_MOSI
DPI_P02 -> SPI0_MISO
DPI_P03 -> SPI0_CLK
Does this mean that the DSP bootloader expects this routing while booting up ?
If that's the case, how do we change the bootloader code such that we can map our hardware routing and reprogram the bootloader ? (Changing the hardware connections at this moment is very difficult. So, we are looking for a software solution!)
Expecting a reply soon,
Aswin
