Power Dissipation
Product Number: ADSP-21369
I am Using ADSP-21369,for the processor I wanted to calculate "Junction temperature @ ambient 25deg". In the datasheet "ADSP-21369 (Rev. H)" to find the Power dissipation its mentioned to refer "Engineer-to-Engineer Note EE-299", but nowhere I could find the Pd. Instead In appendix D, To calculate Tj,  said to use total Power consumption of processor in the formula "Tj = Ttop + (PTOTAL x ψJT)
Please let me know the which formula to be followed to calculate TJ,  Either Tj = TT + (PTOTAL x ψJT) or Tj= Ta + (θJA × Pd) and Where I can find Pd for the ADSP-21369.
Regards
Ayyappan A
  • Hi Ayyappan,
    As per Application note EE-299, To determine the junction temperature of the device while on the application printed circuit board (PCB), use the following equation found in the THERMAL CHARACTERISTICS section of the data sheet:
    The THERMAL CHARACTERISTICS section of the data sheet also provides thermal resistance (θJA) values for the 256-ball Super BGA, 208-lead MQFP and LQFP packages. Data sheet values for θJA are provided for package comparison and PCB design considerations only and are not recommended for verifying TJ on an actual application PCB and you can use the PTOTAL value for PD.
    Divya.P
  • Hi Divya
    Could you please assist me in providing Junction to Board Resistance for ADSP-21369 LQFP_EP package
    Regards
    Ayyappan A
  • Hi Ayyappan,
    Junction to board measurements compile with some standards. The values may vary for different boards. So, we couldn't able to share that information.
    Divya.P
