How to Configure S/PDIF Receiver Device Register Errors - ADSP-21479 EZ-Kit Lite
I am using the ADSP-21479 EZ-Kit and tinkering with the example code for SPDIF to Analog talk through with SRC.
I am trying to program a "No Stream Error" to occur whenever the audio stream is disconnected from the S/PDIF receiver.
How can I setup my initSPDIF() to assert the DIR_NOSTREAM bit from the DIRSTAT register? I am a unsure of the correct coding syntax.
My function currently:
InitSPDIF()
/* SPDIF Setup code goes here */
/* Init SPDIF transmitter in I2S mode */
*pDITCTL = (DIT_EN | DIT_IN_I2S | DIT_AUTO);
/* Use default setting of SPDIF receiver */
*pDIRCTL=0x0;
/* SPDIF Receiver Register Status */
*pDIRSTAT = (DIR_NOAUDIOLR | DIR_VALID | DIR_LOCK | DIR_NOSTREAM);
SPDIF_GetError ()
// How to check if pointer bit is one or zero?
if(*pDIRSTAT == DIR_NOSTREAM)
Thanks in advance,
Calum
