ADSP-SC584 EZ-Board extend P1A P1B P1C
Hello ,
I work with ADSP-SC584 EZ-Board and I need connect to P1A P1B P1C
I found ADZS-BRKOUT-EX3 but it is good for P1A and P1B only, I need 3 connectors in the same time , Did ADI have the board similar to ADZS-BRKOUT-EX3, but for 3 connectors at the same time P1A P1B P1C ?
    You can connect extenders to all the ports P1A P1B and P1C simultaneously. You can use two separate extenders as given below.
    1. Connect 1st extender E1 J2 to P1A.
    2. Connect 2nd extender E2 to P1B and P1C. Note that in this case, J1 will be connected to P1B and J2 to P1C. Use the corresponding J1/J2 pins in the extender.
    In this way, you can simultaneously use P1A P1B and P1C. There is no way to use three extenders separately.
    Please let us know if you need further assistance on this.
    Lalitha S
