Re: Need a code example of slave spi-dma for 21262
Dear Jeyanthi :
                          I download your attached file 21262_SPI_Slave.zip, I have some question hope you can help me ?
1.The attached file code is for SPI slave recevice?
2.Do you have example code is for SPI slave transmit?
3.Can you give some advice to me about my problem? I really don't know where is the problem!  Thanks so much!
  http://ez.analog.com/message/25166#25166
  • Hi Pingu,
               The 21262_SPI_Slave example code uses the SPI slave in receive mode. The same code can be modified for transmit operation as below:
    void main()
    *pSPICTL = 0;
    interrupt(SIG_SPIH, Transmit_data);
    *pSPICTL =  SPIEN | TIMOD1 | WL32;
    while(1)
      asm("nop;");
    void Transmit_data(int i)
    *pTXSPI =  source[int_count];
    int_count++;
    if(int_count >= N)
      *pSPICTL = 0;
    Regarding the issue seen on the other post, I could see that Mitesh has suggested few things on his last post. It will be good if you can post your follow-up questions on the same post to avoid any duplication efforts.
    Hope this helps.
    Best Regards,
    Jeyanthi
