Load 21469 via 8 bit bus
  I have a board with a Adsp 21469 Chip.  I am trying to program the chip but the board I have has only an 8 bit bus and the default kernel is using a 32 bit bus.  What needs to change in the kernel to load via the 8 bit bus?
Steve
  • Hi Steve,
    I looked at the default boot kernel "469_prom.asm". It doesn't seeem to have a AMICTLx programming. Could you please confirm which boot kernel and what type of memory initialization (AMI/DDR2DRAM)  you are referring to ?
    Mitesh
