Knowing latencies of interrupt from external peripheries on ADSP-SC58x
I would like to know how much cycles would be taken when interrupt came from external peripheries, for example PINT0 ?
I assume System Event Controller might take cycles but I could not find descriptions in HRM and PRM.
I only find following in regard to cycles in processor core in HRM and this EngineerZone as DOC-12405(What is the minimum latency between a Core interrupt and the branch to the IVT?), has to be add to the cycles consumed in SEC.
The processor responds to interrupts in three stages:
  1. Synchronization (1 cycle)
  2. Latching and recognition (1 cycle)
  3. Branching to the interrupt vector table (11 instruction cycles)
If the branch is taken from internal memory, the 11 instruction cycles corresponds to 11 core clock cycles. If the branch is taken from external memory, the 11 instruction cycles may span over many more clock cycles depending on the actual source of the instruction and the state and configuration of the system.
Your helps always be appreciated.
Best Regards,
Parents
  • Hi Takehisa
    We measured interrupt latency on SC589 as around 822ns / 370 Core Clock Cyces @450Mhz of Core Clock Frequency. This was tested using the software interrupts routed to SEC and measuring the time difference between the write to SEC_RAISE register and the first instruction inside the ISR. The number is on using default CCES handlers. You should see approximately same numbers for the external peripheral case, perhaps few core clocks additional since it has to latch from external domain.
    Thanks
    Prasanth
Reply
  • Hi Takehisa
    Thanks
    Prasanth
Children
No Data
