SPDIF
FormerMember
FormerMember
Product Number: AVR9
Software Version: CCES 2.11.1
Dear Team,
I have already posted a query in another link but did not receive any reply. In the meantime I have made some progress so I am updating my question below:
In the SPDIF Loopback example why is the Clock source selected as AD_PCG_CLKIN0 .
In my case considering AVR9 when I select the Source as external DAC output is fine but no Output from SPDIF Tx
Please correct my SRU routing if its not appropriate
SRU(LOW,DAI0_PBEN05_I); // External MCLK from 24.576MHz Oscillator
SRU(LOW,DAI1_PBEN07_I); //DAI 1 Pin 07 is connected with MCLK In pin of AD1939 Codec
SRU(DAI1_PB07_O,PCG0_EXTCLKA_I); // MCLK to PCG C
SRU(PCG0_CLKA_O,DAI1_PB03_I);
SRU(PCG0_FSA_O,DAI1_PB04_I);
SRU(DAI1_PB04_O,SPDIF1_TX_FS_I);
SRU(DAI1_PB03_O,SPDIF1_TX_CLK_I);
SRU(PCG0_CLKB_O,SPDIF1_TX_HFCLK_I);
SRU(SPT4_AD0_O,SPDIF1_TX_DAT_I);
/********************Direct SPDIF In to Out Routing just for confirmation ************************/
SRU(SPDIF1_TX_O,DAI1_PB20_I);
SRU(HIGH,DAI1_PBEN20_I);
Hermione
Edit
[edited by: Hermione at 2:04 PM (GMT -5) on 18 Jan 2024]
  • Hi Hermione,
    While looking into the SRU routing you shared, you need to configure the DAI1_PB03_I and DAI1_PB04_I as high. Please refer the below snippet.
    SRU(HIGH,DAI1_PBEN03_I);
    SRU(HIGH,DAI1_PBEN04_I);
    Please refer the "Pin Buffer Signals" section in the HRM manual for more information.
    We would suggest you to refer the SPDIF example code available in the ADSP-2156x BSP package. In the example, PCG is configured to use 24.576 Mhz External clock as source and PCG output clock & FS is fed to ASRC Output(at 192KHz). You can download and install the ADSP-2156x BSP from the link given below.
    download.analog.com/.../ADI_EV-2156x_EZ-KIT-Rel1.0.1.exe
    After installation, you can navigate the example from the below mentioned installation path.
    [Installation directory]:\Analog Devices\EV-2156x_EZ-KIT-Rel1.0.1\EV-2156x_EZ-KIT\Examples\drivers\adc\SPDIF_ASRC_DAC_AudioPassthrough
    Please use this code as a reference and modify as per your requirement for ADSP-2159x.
    Divya.P
