how can I simulate SC589 ? with IBIS model or spice model? which simulation software can I use?
simulating circuit which i interest in adsp-cs589 EZ broad
    on May 5, 2021 12:44 PM
    The CCES supports simulation of the below SHARC+ cores. ARM core simulation is not supported.
    One SHARC+ core in a:
    One-, two-, or three-core ADSP-SC5xx project
    Two-core ADSP-215xx project
    Both SHARC+ cores simultaneously in a:
    Two- or three-core ADSP-SC5xx project
    For more details on using CCES simulator, please refer the CCES help path. You can navigate as given below.
    CrossCore® Embedded Studio 2.9.3 > Integrated Development Environment > Debugging Targets > Debugging ADSP-215xx SHARC+ Projects > Using CrossCore Functional Simulator for an ADSP-215xx Application (SHARC+ Debug)
    Also note that, when your application involves peripherals, hardware accelerators or external memory you may not be able to use simulator mode. You will need hardware to run the application.
    Please let me know if you need further assistance on this.
    Anand Selvaraj.
