DDR3 CLK/DQS termination for ADSP-SC589
There is some contradiction between EE387 and actual ADSP-SC589 Ez-Board schematic.
EE387 states following:
"the DMC_CK signal requires a pull-up resistor and the DMC_CK# signal requires a pull-down resistor that is placed close to the memory"
and
"the DMC_UDQS/DMC_LDQS signal requires a pull-up resistor and the DMC_UDQS#/DMC_LDQS# signal requires a pull-down resistor closest to the memory"
Actual Ez-Board schematic doesn't have neither of them. So, are these terminators required/recommended or not?
Thank you,
Eugene
