Attached test is to check the RS-232 communication with PC using UART. In this code, UART receives a character from the PC and loops it back. So, at the hyperterminal, the character sent out should be echoed back.
Hi Vinod ,
I compiled the program in Cross Core 2.2.0 and run it on SC589 eval kit Rev 1.6 then i got the following run time error ..
A non-recoverable error or exception has occurred.
Description: No dispatched handler available for the specified interrupt code.
General Type: RunTimeError
Specific Type: NoDispatchedHandler
Error PC: 0xc10046d8
can you help with this?
Thanks
Please see the attached standalone code which works fine using CCES.
In order to test this:
You can use this as reference.
Harshit
