Need help choosing the correct DSP
The user seeks an IC capable of encoding 2-4 and decoding/mixing 8-12 audio channels at 48KHz, 16-bit, 2.5ms frames using lc3plus. The ADSP-2156x and ADSP-SC59x/2159x processors are recommended for this task, offering high-performance floating-point cores and advanced DSP accelerators. The user is advised to consider the ADAU1777 for front-end processing and connect it to the MCU/DSP over I2S if the proposed chip's amps do not match or exceed those of the ADAU1777.
Product Number: ADSP-SC598
Hi there,
I'm looking for an IC that can simultaneously:
- Encode 2-4 audio channels of 48Khz, 16-bit, 2.5ms frames, using lc3plus.
- Decode and mix 8-12 audio channels of 48Khz, 16-bit, 2.5ms frames, using lc3plus.
1. Can you recommend such a chip? (If the ADSP-SC598 is an overkill, which one can do this cost-effectively?)
2. Is lc3plus easily supported as a pre-compiled library, or as a "block" in a visual design tool? I'm ok with C/C++ programming as/if needed.
3. Is there built-in support for UAC2 over USB if I want to connect the system to a DAW / digital mixer?
4. I already have an ADAU1777 in my current design. Would you recommend leaving the ADAU1777 in place as a Front-End audio processor and connect it to the MCU/DSP over I2S, or do the amps on the proposed chip match or exceed those of the ADAU1777, in which case I can remove the ADAU1777 from the design?
Thanks in advance,
Nir
  • Hi Nir,
    Please refer the below information about SHARC processors.
    Analog Devices' SHARC® processor family dominates the floating-point DSP market with exceptional core and memory performance and outstanding I/O throughput. With multiple products variants and price points, SHARC brings real-time floating-point processing performance to many applications where dynamic range is key. The latest products provide leading performance/power efficiency and advanced connectivity with an integrated ARM® core.
    New multi core processors are the latest in a growing series of high-performance, power-efficient, real-time platforms that deliver greater than 6 giga-floating-point operations per second using two enhanced SHARC+ cores and advanced DSP accelerators (FFT, FIR, IIR).
    The latest ADSP-2156x processors provide enhanced SHARC+ high performance floating-point core up to 1 GHz. The ADSP-2156x series of processors are designed to provide immersive audio and sound experience in automotive and consumer/pro-audio applications. You can find more information about these processors from the link below.
    www.analog.com/.../adsp-2156x-family.html
    The ADSP-SC59x/2159x family are single- or dual-SHARC+ DSP core floating-point processors.
    www.analog.com/.../adsp-sc59x-adsp-2159x-series.html
    Please use the below parametric search link to choose the processors
    www.analog.com/.../11128
    We have Processors Software and Tools page provides a convenient look-up table to indicate to users what evaluation platforms, extender cards, emulators, software development tools, and middleware are available for the specific processors you have chosen to evaluate for your designs.
    SHARC - www.analog.com/.../sharc-processors-software-and-tools.html
    For more details on pricing and availability questions, please contact your nearest ADI sales and distributors. Please find the link given below.
    www.analog.com/.../find-sale-office-distributor.html
    We have evaluation kits available for different processors which will provide a platform for customer to evaluate our DSPs. When you navigate through our product specific page you will find its evaluation platform with associate.
    If you can provide more information on other requirements from the external interfaces, the speed grade, memory requirements, package, which you are looking for, then we can help you narrow down to select the right derivative in processor family.
    Regards
    Nandini C
