Based on BSP downloaded from here:
download.analog.com/.../ADI_EV-SC59x_EZ-KIT-Rel4.0.0.exe
and examples from
[Installation path]\Analog Devices\EV-SC59x_EZ-KIT-Rel4.0.0\EV-SC59x_EZ-KIT\Examples\drivers\ospi\ospi_flashdirectaccess
I tried the code snippet mentioned. Further modified a few things of the ADI_OSPI_DAC_CMD DAC_Read_Command2 and tried.
The aim is to Read from Flash using memory mapped IO from address specified like 0x60005800.
I am trying only Read from Flash via Direct Access Control. Non-DMA mode is intended.
However, no data is being read. All values are zeros.
However, the result of driver function calls are all ADI_OSPI_SUCCESS.
Attached herewith in the .txt file are the various code snippet modifications done. They mainly differ in the parameters assigned to DAC_Read_Command2.
Can you please let me know what is likely to have been missed and why only zeros are obtained in the ReadBuffer?
Modification Case 1:
ADI_OSPI_DAC_CMD DAC_Read_Command2;
#if 1
/* Buffer into which the data from Flash is read in to */
#define READBUFFSIZE 0x128
uint8_t ReadBuff[READBUFFSIZE];
ADI_OSPI_RESULT eResult = ADI_OSPI_SUCCESS;
uint8_t nDriver_Memory[ADI_OSPI_MEMORY_SIZE + ADI_SPU_MEMORY_SIZE];
#define MDMA_CHANNEL_USED ADI_DMA_MEMDMA_S0
/* Initialize OSPI controller */
//if(Ospi_initialize() != 0U)
// return 0;
/* Handle for OSPI driver */
uint32_t HandleMem = 0;
ADI_OSPI_HANDLE *phDevice = (ADI_OSPI_HANDLE*)&HandleMem;
DAC_Read_Command2.CmdOpcode = 0x03; // /*(0x0B)Fast Read mode */ /*(0x03)Normal Read mode */
DAC_Read_Command2.CmdOpcode2 = 0;
DAC_Read_Command2.eBusMode = ADI_OSPI_SINGLE;
DAC_Read_Command2.eTransferMode = ADI_OSPI_TRANSFERMODE_STR;
DAC_Read_Command2.eOperatingMode = OSPI_ADI_COREMODE;
DAC_Read_Command2.eAddrSize = ADI_OSPI_CMD_ADDR_SIZE_3;
DAC_Read_Command2.NumOfDummyCycles = 8;
DAC_Read_Command2.ModeDataEnable = 1; // check for 0
DAC_Read_Command2.ModeData = 0;
DAC_Read_Command2.pSource = (uint8_t *)0x60000000;
DAC_Read_Command2.pDestination = (uint8_t *)ReadBuff;
DAC_Read_Command2.nCount = READBUFFSIZE; // tried 16 earlier
eResult = adi_ospi_Open((uint8_t *)nDriver_Memory + ADI_SPU_MEMORY_SIZE,
ADI_OSPI_MEMORY_SIZE,
OSPI_ADI_MDMAUSED,
MDMA_CHANNEL_USED,
phDevice
if(eResult != ADI_OSPI_SUCCESS)
printf("Failed to Open OSPI driver. Error code returned %d \n", eResult);
return -1;
eResult = adi_ospi_ConfigBaud(*phDevice, ADI_OSPI_BAUD_DIV_BY_32);
printf("Failed to update the Baud rate. Error code returned %d \n", eResult);
return -1;
eResult = adi_ospi_UpdateReadDelay(*phDevice, 8);
printf("Failed to update the Read delay capture value. Error code returned %d \n", eResult);
return -1;
/* Perform the read operation in the configured mode of OSPI and flash */
eResult = adi_ospi_DirectRead( *phDevice, &DAC_Read_Command2);
printf("Error occurred in OSPI Direct Read. Error code returned %d \n", eResult);
printf("Fail \n");
return 0;
/* Close the OPSI driver */
eResult = adi_ospi_Close(*phDevice);
printf("Failed to Close OSPI driver. Error code returned %d \n", eResult);
printf("Fail \n");
return 0;
#else
Modification #2: Changed the source address to 0x5800
#if 1
#define READBUFFSIZE 128U
// return 0;
DAC_Read_Command2.pSource = (uint8_t *)0x00005800; // Tried this also (uint8_t *)0x60000000;
OSPI_ADI_MDMAUSED,
MDMA_CHANNEL_USED,
phDevice
return -1;
return -1;
return -1;
printf("Fail \n");
return 0;
printf("Fail \n");
return 0;
#else
Modification #3: Made NumOfDummyCycles, ModeDataEnable and ModeData all 0.
#if 1
// return 0;
DAC_Read_Command2.NumOfDummyCycles = 0;
DAC_Read_Command2.ModeDataEnable = 0; // check for 0
OSPI_ADI_MDMAUSED,
MDMA_CHANNEL_USED,
phDevice
return -1;
return -1;
return -1;
printf("Fail \n");
return 0;
printf("Fail \n");
return 0;
#else
