Inconsistencies between 21569-SOM schematic and DSP datasheet
Category: Datasheet/Specs
Product Number: ADSP-21569
Hi there,
we found an inconsistency between the pin assignment in the schematic of the ev-21569-som-schematic.pdf and the datasheet of the 21569 processor.
See below.
I assume, GND is used as negative reference voltage for the housekeeping ADC.
If this is something that anyone at ADI has to worry about, please do so.
If not this can probably be ignored as "not good style".
Rainer
  • Hi Rainer,
    Regarding "I assume, GND is used as negative reference voltage for the housekeeping ADC."
    >> Yes, your understanding seems correct. The housekeeping ADC uses GND as its negative reference voltage. Please refer the below image.
    Regarding "we found an inconsistency between the pin assignment in the schematic of the ev-21569-som-schematic.pdf and the datasheet of the 21569 processor."
    >> Thank you for pointing this. We will check and update as soon as possible.
    Ranjitha. R
  • Hi Rainer,
    We will update the documentation in the future release.
    Meanwhile, you can follow the EV-21569-SOM schematic as a reference.
    Nandini C
