PCG CLK when working for SPORT TDM mode
Product Number: ADSP-21593
My 21593 is using a 25MHZ crystal, and now I want to config my SPORT 0 working at TDM16 with 32bit, The clock should be 24.576MHz and FS should be 48KHz. However when I config the PCG I meet some problem, it seems the CLK can't be divide to 24.576MHz. and using "adi_sport_ConfigClock" function meet the same problem. What can I do to config my TDM clock?
Thanks
    We would suggest you refer the below FAQ link:
    ez.analog.com/.../adsp-sc594-spdif-example
    In this example we are providing the 24.576Mhz input to the PCG from the DAI pin externally. This will be done by the SRU ("SRU(DAI1_PB03_O,PCG0_EXTCLKA_I);").
    Note: There is a typo in the Readme block diagram. DAI103 actually takes 24.576 MHz not 25.476MHz
    PCG configuration part is helpful to understand about input clock selection . So, You can take this as reference, and you can modify as to TDM mode. Hope this will clarify.
    You can also refer to the "SPORT_TDM_Mode" examples from ADSP-21593 BSP.
    Download the BSP of ADSP-21593 using below link:
    download.analog.com/.../ADI_EV-SC59x_EZ-KIT-Rel2.0.0.exe
    After installation, you can navigate the example from the below mentioned installation path.
    path: \Analog Devices\EV-SC59x_EZ-KIT-Rel2.0.0\EV-SC59x_EZ-KIT\Examples\drivers\sport
    For details on how to program clock divisor for PCG using PCG_CTLxx registers, please refer to the Hardware Reference Manual below:
    www.analog.com/.../adsp-2159x-sc591-592-594-hrm.pdf
    Also, please refer the below ezone thread, which might be helpful to you.
    ez.analog.com/.../in-adsp-21593-if-i-want-to-set-sport0a-as-i2s-rx-and-the-bit-clk-and-fs-clk-are-externally-provided-do-i-need-to-config-the-sport-clock-and-framesync
    Ranjitha R
  • Hello Ranj,
    So for the 24.576MHz it can only be provided by external and input from DAI right? there is now way for ADSP itself to produce a 24.576MHz with a 25MHz crystal. is my understand correct?
    Siyu
    Yes, your understanding is correct.
    Please let us know if you need any further assistance.
    Ranjitha R
  • Hi Ranji,
    I see the documents and demo code and I use a SRU function connect the dai0_P15 to PCG clk in
    SRU(DAI1_PB15_O,PCG0_EXTCLKA_I); ,and I config the PCG as :
    void PCG_init(void)
        ADI_PCG_CLK_INFO gClkInfoA =
            ADI_PCG_CLK_EXT,              /* Clock Source */
            1u,                             /* Clock Divisor */
            false                           /* External Trigger */
        ADI_PCG_FS_INFO gFsInfoA =
            512u,                            /* Frame Sync Divisor */
            256u,                           /* Pulse Width */
            4u,                             /* Phase */
            false,                           /* External Trigger */
            ADI_PCG_FSBYPASS_MODE_NORMAL     /* Bypass Mode */
        adi_pcg_Init(ADI_PCG_DEV_A,&gClkInfoA,&gFsInfoA);
    However when I measure the output of SPORT0A the clk is HIGH and framesync is LOW, is the way I use PCG error or some other reason?
    Siyu
    Since you are configuring clock and Frame sync selected from the external PCG. You need to configure Frame sync external source as "ADI_PCG_FS_EXT" instead of "ADI_PCG_CLK_EXT" under PCG FS configuration.
    Please find the below code snippet.
            ADI_PCG_FS_EXT,                /* Clock Source */
            4u,                             /* Phase */
    Ranjitha R
  • Thanks Ranji, I found that if change external CLK to DAI0PB07 it can work now. Thanks a lot for your help. it has been solved now.
